coq-club - Re: [Coq-Club] Add Relation sequence bisimilar
chronological Thread
  • To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Add Relation sequence bisimilar
  • Date: Thu, 30 Apr 2009 15:06:34 +0200
Keiko Nakata wrote:
Hello,
Are there any potentially bad consequences of having "Add Relation sequence bisimilar", where sequence and bisimilar are defined coinductively, i.e. infinite lists and the bisimilar relation on them?
I am aware of an issue concerning type preservation discussed:
http://logical.saclay.inria.fr/coq-puma/messages/b35593715e6cbad3#msg-b35593715e6cbad3
I also remember someone told me that he suspect that there might be
some bad interactions between Coq's criterion of guardedness and Setoids.
I was thinking if, with "Add Relation sequence bisimilar", any predicate on sequences will not distinguish bisimilar lists; this sounds interesting to me.
Best regards,
Keiko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
I don't know if this is relevant, but Christine Paulin has a development where she uses streams and and coinductive relations in the framework of setoids. You can have a look at it by following these links:
http://www.lri.fr/~paulin/PUBLIS/paulin07kahn.pdf
http://www.lri.fr/~paulin/KahnNetworks/library.pdf
http://www.lri.fr/~paulin/KahnNetworks/HTML/all-gal.html
http://www.lri.fr/~paulin/KahnNetworks/kahn-networks.tgz
I hope this helps,
Yves
