coq-club - [Coq-Club] Proofs preserved by a certain equivalence relation
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Proofs preserved by a certain equivalence relation
  • Date: Sat, 16 May 2009 19:03:36 +0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=HznaIjyJy2y7QggJXrnhwu9H1rIa/kBiGhUNiAUnvcCLfoh+dPV0fYvpjM+MDVqPCY lKtKjdcCB48lq76W7dxUp/o0JuUXVaI5nfV0p1vXrYuRZzOqZ7Sei4B72RszNxHZkIJh zvClm4PMnjH4uu86xRTi64FcgIV2n0dMNtnY0=
Hello.
I'm doing some proofs with FSet and FMap, and I run a lot into the
problem that I can't use the 'rewrite' tactic or alike, because some
sets are related only by FSetInterface.eq, not by the global eq.
I thought that it would be cool to use a meta-technique that allows to
judge about properties preserved by an equivalence relation.
Suppose that R is an equivalence relation on type T.
Then let's say that the algebra ALG of proofs of certain properties
about objects of type T, defined as
Inductive ALG : T->Prop := ...
 is preserved by R if
 forall (theorem:ALG) (a b:T), R a b -> theorem a -> theorem b.
Then, for FSet, I could define an algebra that would describe proofs
that only use the abstract properties of FSetInterface and are
preserved by FSetInterface.eq, I'd prove that this algebra is indeed
preserved by it, and probably I could create something like my own
rewrite tactic for FSetInterface.eq afterwards.
However, although it sounds cool, I am afraid that this would be a
huge lot of work, and I don't even know where to start.
Are there any similar formalizations at which I could have a look for
inspiration? Is this sort of thing actually tractable and practical
enough?
Eugene Kirpichov
Web IR developer, market.yandex.ru
