coq-club - Re: [Coq-Club] examples of program by extraction?
chronological Thread
  • To: Wouter Swierstra <wss AT cs.nott.ac.uk>, coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] examples of program by extraction?
  • Date: Thu, 28 May 2009 17:54:18 +0900
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=NUGdf8ou6fFczyXtnqjQsiXPl2Je+g4EW/sBTyyeg7Cxds9mK7ghOiL70qESuPa2+b pIcFGzfq/IlcjUrzDiMRUM37rln4Vk+IlKqKDGOzp2Q0ZQ1iJXisRupy6icfv70jFNSX 9lpOGgER+pGT1vOLkMAC51KVvQqUP3JGWDoQI=
Thank you very much for your answers although my question was a bit vague.
(I could not specify my question.)
What I learned from the answers is that many people are doing
intensive research on program extraction.
I will have look at the references and then try to start with something.
All the best,
Gyesik
On Sat, May 23, 2009 at 4:02 AM, Wouter Swierstra
 wrote:
> Hi Gyesik,
>> I am looking for some practical examples of program by extraction using
>> Coq.
> I'm not sure if it counts as practical, but I recently had a paper accepted
> that really showcases some of the new "correct-by-construction" programming
> that is possible in Coq:
> http://www.cse.chalmers.se/~wouter/Publications/HoareStateMonad.pdf
> I've also implemented (most of) the core data types that are present in
> XMonad (a window manager written in Haskell) in Coq and proven some small
> properties. I'm working on getting the extracted Haskell code as close as
> possible to the original, hand-written version:
> http://www.haskell.org/pipermail/xmonad/2009-May/007881.html
> Hope these examples help. All the best,
>  Wouter
