- From: "Vincent Siles" <vsiles AT lix.polytechnique.fr>
- To: "Chris Dams" <chris.dams.nl AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How to make mutual recursive theorems?
- Date: Sun, 31 May 2009 08:06:56 +0200 (CEST)
- Importance: Normal
Hi !
There are two ways to deal with mutually inductive theorems:
1) As Yves said, you can rebuild the induction principles with the Scheme
command to make them dependent,
but he forgot to mention that you can combine them to build a mutual
fixpoint:
Scheme mutual_ind_A := Induction for A Sort Prop
with mutual_ind_B := Induction for B Sort Prop.
Combined Scheme mutual_ind_AB from mutual_ind_A, mutual_ind_B.
Afther this, you can state your theorem this way:
Theorem foo: ( forall a:A, P a) /\ (forall b:B , Q b).
apply mutual_ind_AB.
Qed.
And the induction hypothesis should be the good ones.
2) The second is more dangerous to use since it's build over the fix tactic:
Theorem fooA : forall a:A, P a
with fooB : forall b: B, P b.
Qed.
What it does is to use the fix tactic to give you two hypothesis
in all the sub-goals, but it's up to you to only apply them on structural
subterms (beware of automation !).
You should also be carefull using inversion : you have to apply fooX
*before* rewriting in a subterm, otherwise
it won't be considered as a structural subterm.
If you want to take a look at some examples, there are some here:
https://www.lix.polytechnique.fr/~vsiles/coq/formalisation.html
in the sequent calculus section.
Cheers,
Vincent
> Chris Dams wrote:
>> Dear all,
>> Imagine that I have a mutually recursive inductive definition like
>> Inductive A: Set
>> := | mk_a: A
>> | S: B -> A
>> with B: Set
>> := | mk_b: B
>> | T: A -> B.
>> And I want induction theorems for this like
>> Theorem mutual_ind_A:
>> forall P: A -> Prop,
>> forall Q: B -> Prop,
>> P mk_a ->
>> Q mk_b ->
>> (forall b: B, Q b -> P (S b)) ->
>> (forall a: A, P a -> Q (T a)) ->
>> forall a: A, P a.
>> Theorem mutual_ind_B:
>> P mk_a ->
>> Q mk_b ->
>> forall b: B, Q b.
>> The only way I know to prove this involves much code duplication. It
>> goes like
> Did you try the Scheme command:
> The theorems it produces have different premise order, but they are
> equivalent to the ones you want.
> Yves
- [Coq-Club] How to make mutual recursive theorems?, Chris Dams
- Re: [Coq-Club] How to make mutual recursive theorems?,
Yves Bertot
- Re: [Coq-Club] How to make mutual recursive theorems?, Vincent Siles
Yves Bertot
