- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Rewriting and eta rule
- Date: Mon, 1 Jun 2009 19:58:42 +0200
(* I apologize if I am somwhat repeating myself, but I would like to
ask advice on how to best do a certain kind of rewriting that involves
matching lambda abstractions (so my expectations are not high).
Suppose we assume extensionality: *)
Axiom extensionality: forall (A B : Set), forall (f g : A -> B),
(forall x : A, f x = g x) -> f = g.
(* We would like to rewrite using the following eta_rule. *)
Lemma eta_rule (A B : Set) (f : A -> B): (fun x => f x) = f.
Proof.
auto using extensionality.
Qed.
Hint Rewrite eta_rule : extrules.
(* However, it's not clear to me how to use eta_rule for rewriting. *)
Lemma test1 (A B C : Set) (g : (A -> B) -> C) (f : A -> B): g (fun x
=> f x) = g f.
Proof.
intros.
(* Attempt 1: rewrite eta_rule. *)
(* Attempt 1 results in:
Error: Abstracting over the term "fun x : A => f x" leads to a term
"fun y : A -> ?17982 => g y = g f" which is ill-typed. *)
(* Attempt 2 does nothing: *)
autorewrite with extrules.
(* But we can tell Coq what we want using patterns. *)
pattern (fun x : A => f x).
rewrite eta_rule.
reflexivity.
Qed.
(* What would be a good way to write a tactic that does the above for me?
It should automatically find a subterm on which the eta rule is
applicable. *)
(* A related question is how to rewrite "f (g x)" to "(comp f g) x" where
"comp"
is function composition: *)
Definition comp {A B C : Set} (f : B -> C) (g : A -> B) (x : A) := f (g x).
Lemma comp_rule (A B C : Set) (f : B -> C) (g : A -> B) (x : A) :
f (g x) = (comp f g) x.
Proof.
auto.
Qed.
Lemma test2 (A B C : Set) (f : B -> C) (g : A -> B) (x : A) :
Proof.
intros.
(* Attempt 1 : rewrite comp_rule. *)
(* Attempt 1 gives:
Error: Abstracting over the term "f (g x) = comp f g x" leads to a term
"fun y : ?18079 => y" which is ill-typed. *)
(* It works if I help Coq with pattern: *)
pattern (f (g x)).
rewrite comp_rule.
auto.
Qed.
(* Actually, what does "ill-typed" the error message mean in this case?
With kind regards,
Andrej
- [Coq-Club] Rewriting and eta rule, Andrej Bauer
- Re: Re[Coq-Club] writing and eta rule,
muad
- Re: Re[Coq-Club] writing and eta rule, Andrej Bauer
- Re: [Coq-Club] Rewriting and eta rule, Taral
muad
