coq-club - Re: [Coq-Club] Problem with rewriting
chronological Thread
  • To: dimitrisg7 <dvekris AT hotmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Problem with rewriting
  • Date: Sun, 07 Jun 2009 09:32:41 -0400
dimitrisg7 wrote:
I would like to get "Var" given by Hypothesis e in the following example.
e : exists v : Var, f_expr_IL v = nth j el dE ============================
   Var
Writing "elim e" I get the error:
Toplevel input, characters 9-15:
Error: Cannot find the elimination combinator ex_rec, the elimination of the
inductive definition ex on sort Set is probably not allowed
The problem is "Var" is an inductive definition of type "Type". Giving "Var"
type "Prop" solves the problem for me. Is there a way to get v without
turning Var's type to Prop?
I hope not, as that would indicate a foundational bug in Coq. You've marked [e] as a proof, and Gallina's type system is supposed to prevent any "information flow" from proofs to non-proofs. Maybe you want a [sig] type instead of an [ex] type for [e].
P.S.: Please don't reply to your old threads with new, unrelated questions. It leads to not-especially-helpful message subjects.
