- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] dependent return type
- Date: Fri, 12 Jun 2009 21:32:41 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=mG7D/wz+lPKDQBZ31ksxyuKDG56sIG4bH3sIQOU6fXT1Dq8TB2bzxFDBywalU46kC0 CZ8knH4Ix49Ulxi472EdMujY7bEbFNw6enUZDDofiS8Hkl8xTjfjhIbUfPYMjFYPNQ9V +84njdsK6/W5HF1kxxQRDNAddiSAnB9ozYow4=
Section test.
(* Hello everyone,
I am having some trouble to define the following operation. The
idea is that you have a type T that is indexed by values in I, and
a cast operation that converts between two different indexed types,
provided that the indices are convertible. The operation would be
to take t : T i1 to F t if it is possible to make the cast, and map
it to tt otherwise. I can define the return type, but I can't
define the actual function. Does anyone have any ideas on how to do
this?
Thanks *)
Variable I : Type.
Variable T : I -> Type.
Variable i1 i2 : I.
Variable dT : T i2 -> Type.
Variable F : forall t : T i2, dT t.
Variable convertible : I -> I -> bool.
Variable cast : T i1 -> convertible i1 i2 = true -> T i2.
Definition dT' (t : T i1) :=
(if convertible i1 i2 as b return (convertible i1 i2 = b -> Type)
then (fun p : convertible i1 i2 = true => dT (cast t p))
else (fun p : convertible i1 i2 = false => unit)) (refl_equal _).
Definition F' (t : T i1) : dT' t.
End test.
- [Coq-Club] dependent return type, Arthur Azevedo de Amorim
- Re: [Coq-Club] dependent return type, Adam Chlipala
- <Possible follow-ups>
Santiago Zanella
- Re: [Coq-Club] dependent return type, Arthur Azevedo de Amorim
