coq-club - Re: [Coq-Club] Use of selective generalize/pattern tactics?
chronological Thread
  • To: Robin Green <greenrd AT greenrd.org>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Use of selective generalize/pattern tactics?
  • Date: Fri, 19 Jun 2009 12:55:25 -0400
Robin Green wrote:
I have just used the "generalize foo at i j k ..." tactic form for the
first time (well, I think it's the first time I've used it, anyway). I
used it to solve a problem with dependent types that I couldn't see any
other reasonable way to solve. Now that I've actually used it, I am
relieved to finally understand how the random-looking list of numbers
one finds at the end of generalize ... at ... tactics can be rationally
arrived at. And, indeed, the numbers at the end of its cousin,
pattern ... at ... (e.g. in le_uniqueness_proof in the Coq FAQ).
I am interested to know in what situations other people use these
particular variants of generalize and pattern - I wonder if I should be
using them more often.
Any use of [generalize] can be replaced by an application of a new lemma. I generally try to solve the kind of problem that you refer to by figuring out the right lemmas, rather than by including opaque lists of occurrence numbers in proof scripts.
