- From: Florian Hatat <florian.hatat AT univ-savoie.fr>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Recursion for list (A * B)
- Date: Wed, 24 Jun 2009 11:04:09 +0200
Dear all,
If I define by hand a type list' (which mimics list (A * B)), I can get
an induction principle "list_prod" :
Variable A : Type.
Variable B : Type.
Inductive list' : Type :=
| nil' : list'
| cons' : prod' -> list' -> list'
with prod' : Type :=
| pair' : A -> B -> prod'.
Scheme list_prod := Induction for list' Sort Type
with prod_list := Induction for prod' Sort Type.
Could I get something similar to this "list_prod" principle, but for
regular lists/pairs of Coq (i.e., which are not mutually inductive)?
Simply replacing "list'" with "list (A * B)" and "prod'" with "A * B" in
the term "list_prod" doesn't work, Coq complains that the recursive call
to F0 is ill-formed. Here is the term, if you want to try:
Definition list_prod' :
forall (P : list (A * B) -> Type) (P0 : (A * B) -> Type),
P nil ->
(forall p : A * B, P0 p ->
forall l : list (A * B), P l -> P (cons p l)) ->
(forall (t : A) (t0 : B), P0 (t, t0)) ->
fun P P0 f f0 f1 =>
fix F (l : list (A * B)) : P l :=
match l as l0 return (P l0) with
| nil => f
| cons p l0 => f0 p (F0 p) l0 (F l0)
end
with F0 (p : A * B) : P0 p :=
match p as p0 return (P0 p0) with
| (t, t0) => f1 t t0
end
for F.
Thank you for your help,
Florian Hatat,
http://www.lama.univ-savoie.fr/~hatat/
- [Coq-Club] Recursion for list (A * B), Florian Hatat
- Re: [Coq-Club] Recursion for list (A * B), Chantal KELLER
- Re: [Coq-Club] Recursion for list (A * B), Adam Koprowski
