coq-club - [Coq-Club] Program + measure -> reduction problems.
chronological Thread
  • To: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Program + measure -> reduction problems.
  • Date: Fri, 26 Jun 2009 17:35:03 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=dNA5BdriuPyrouJpIQBpsEhGiRiQTdLTArT6d32A3gvLiU+MfeePNsFVZnZfwEMiQO kfp7MZofNCktqN2nQAzinjUziBtnyjdaX6n5na3zKZaTl37ZMa4ef32w9G0VXiXMM3nf MEHBig3wDq6w71UOaDUrcpbTnTVpLFlR79YTQ=
   Dear all,
  I have problems with reducing a function defined by means of a Program with a measure. The manual promises:
The reduction is a little more involved, although it works using lazy evaluation;
  This does not seem to be the case for me. Attached please find a simplified example showing the problem. The [eval] function does not reduce as expected, see the last line. Few comments:
   Any help greatly appreciated,
   Adam
Require Import Relations Program Wf.
Set Implicit Arguments.
Section Acc_fun_image.
  Variables (A B : Type) (R : relation A) (S : relation B) (f : A -> B).
  Variable RS_spec : forall x y : A, R x y -> S (f x) (f y).
  Lemma acc_fun_image : forall x, Acc S (f x) -> Acc R x.
  Proof. Admitted.
End Acc_fun_image.
Inductive X : Type -> Type :=
| Nil : X True
| Seq : forall A B, X A -> X B -> X (A * B).
Inductive Res (T : Type) : Type :=
| Ok (res : T)
| Fail.
Definition ctx := { T : Type & (X T * nat)%type }.
Definition build_ctx (T : Type) (x : X T) (n : nat) : ctx := existT _ T (x, n).
Axiom x_measure : relation ctx.
Axiom x_measure_wf : well_founded x_measure.
Program Fixpoint eval (T : Type) (x : X T) (n : nat)
  { measure (build_ctx x n) (x_measure) } : Res T :=
  match x return Res T with
  | _ => @Fail T
  end.
Next Obligation.
Proof with auto.
  unfold MR. intro x.
  apply acc_fun_image with (S := x_measure)
    (f := fun (x : {T : Type & { _ : X T & nat}}) =>
    let xx := projT2 x in build_ctx (projT1 xx) (projT2 xx))...
  apply x_measure_wf.
Defined.
Eval lazy in eval Nil 0.
Adam.Koprowski AT gmail.com, http://www.cs.ru.nl/~Adam.Koprowski
The difference between impossible and possible
lies in determination (Tommy Lasorda)
