- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Extracting several elements of a tuple at once
- Date: Sat, 1 Aug 2009 21:05:14 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=pY+ap1fDWZbqDapYhQwZcdL7IPfE8Qpny0RmWyoSPurDM/GWF4EL/BusI+g9tzXzsz HMd87sDm851vYcN5NLvLYk494zrrkqOwUa4Brsx3Oo3memQmC9fbh/4Lqrjmvs1YL8fo yfLFdOnrrCJluLOqu56JhUcp/jO8A8jIlpE5k=
Hello list,
this is probably a basic question (I'm a newbie) but anyway, here it
goes... If abcdefg is a 7-uple - with a complex dependent type - is
there a way to extract all its components at once? Something like this
would be ideal,
Definition (a, b, c, d, e, f, g) := abcdefg.
but this is not accepted...
Let me explain how I arrived at this problem. I am trying to use Coq
to formalize a certain notation that I have been using for years for
doing constructions and proofs in Category Theory, and I tried to do
this:
(* ------ snip, snip ------ *)
Definition type_of (T : Type) (t : T) := T.
Implicit Arguments type_of [T].
Section Categories.
Variable C_0 : Type.
Variable Hom_C : C_0 -> C_0 -> Set.
Variable id_C : forall (A : C_0), Hom_C A A.
Variable o_C : forall (A B C : C_0) (g : Hom_C B C) (f : Hom_C A B),
Hom_C A C.
Implicit Arguments o_C [A B C].
Variable idL_C : forall (A B : C_0) (f : Hom_C A B),
(o_C (id_C _) f = f).
Implicit Arguments idL_C [A B].
Variable idR_C : forall (A B : C_0) (f : Hom_C A B),
(o_C f (id_C _) = f).
Implicit Arguments idR_C [A B].
Variable assoc_C : forall (A B C D : C_0)
(f : Hom_C A B) (g : Hom_C B C) (h : Hom_C C D),
(o_C h (o_C g f) = o_C (o_C h g) f).
Implicit Arguments assoc_C [A B C D].
Definition C := (C_0, Hom_C, id_C, o_C, idL_C, idR_C, assoc_C).
Definition C_minus := (C_0, Hom_C, id_C, o_C).
Definition Category := type_of C.
Definition Protocategory := type_of C_minus.
Variable D : Category.
Definition (D_0, Hom_D, id_D, o_D, idL_D, idR_D, assoc_D) := D. (* <- *)
Definition D_minus := (C_0, Hom_C, id_C, o_C).
(* etc... *)
end Categories.
It would be fantastic if the "(* <- *)" line above would be accepted,
but it isn't... Any hints, suggestions, pointers, workarounds (using
records, maybe)?...
Thanks in advance,
Eduardo Ochs
eduardoochs AT gmail.com
http://angg.twu.net/
- [Coq-Club] Extracting several elements of a tuple at once, Eduardo Ochs
