coq-club - Re: [Coq-Club] print string in coq-8.1.pl3
chronological Thread
  • To: reaz <reazshawon AT gmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] print string in coq-8.1.pl3
  • Date: Tue, 04 Aug 2009 08:29:35 +0200
reaz wrote:
Consider following code segment. I want to print messages in <>.
Fixpoint sel_stmt (s: Cminor.stmt) : stmt :=
  match s with
  | Cminor.Sskip => Sskip <print "skip">
  | Cminor.Sassign id e =>  Sassign id (sel_expr e) <print "assign">
  | Cminor.Sstore chunk addr rhs => store chunk (sel_expr addr) (sel_expr
rhs) <print "store">
  | Cminor.Scall optid sg fn args =>
      Scall optid sg (sel_expr fn) (sel_exprlist args) <print "call">
| Cminor.Stailcall sg fn args => Stailcall sg (sel_expr fn) (sel_exprlist args)
  | Cminor.Sseq s1 s2 => Sseq (sel_stmt s1) (sel_stmt s2)
  | Cminor.Sifthenelse e ifso ifnot =>
      Sifthenelse (condexpr_of_expr (sel_expr e))
                  (sel_stmt ifso) (sel_stmt ifnot)
  | Cminor.Sloop body => Sloop (sel_stmt body)
  | Cminor.Sblock body => Sblock (sel_stmt body)
  | Cminor.Sexit n => Sexit n
  | Cminor.Sswitch e cases dfl => Sswitch (sel_expr e) cases dfl
  | Cminor.Sreturn None => Sreturn None
  | Cminor.Sreturn (Some e) => Sreturn (Some (sel_expr e))
  | Cminor.Slabel lbl body => Slabel lbl (sel_stmt body)
  | Cminor.Sgoto lbl => Sgoto lbl
  end.
You can't print at these locations. It looks like you want to "trace" the execution of your function. To do so, I would suggest extracting some OCaml code and then adding print statements in the Ocaml code, which is often quite readable.
Of course, it is not advisable to keep this kind of code that is partly obtained mechanically and partly modified by hand, but for understanding and debugging purposes, it may be useful.
I hope this helps,
Yves
