- From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
- To: Benjamin Pierce <bcpierce AT cis.upenn.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>, Martin Hofmann <mhofmann AT tcs.ifi.lmu.de>
- Subject: Re: [Coq-Club] Dealing with lets
- Date: Thu, 06 Aug 2009 00:01:27 -0400
Quoting Benjamin Pierce
<bcpierce AT cis.upenn.edu>:
Suppose we start a development like this...
Definition good (f : nat->(nat*nat)) :=
forall a,
let (x,y) := f a in
x < y /\ a < x.
Definition compose (f g : nat->(nat*nat)) :=
fun a =>
let (x,y) := f a in
let (u,v) := g y in
(x,v).
Lemma compose_is_good :
forall f g,
good f -> good g -> good (compose f g).
Proof.
(* Here are two ways of completing the proof. The first proof is
essentially what I came up with originally, but the second is
shorter. In both proofs, I used [omega] to reason about
arithmetic. *)
Require Import Omega.
forall f g,
Proof.
unfold good, compose.
intros f g J1 J2 a.
(* The main observation is that the "destructuring [let]s" here are
each syntactic sugar for a [match], so we can simplify each one
the same way we would simplify a [match]: by performing a case
analysis on the term being analyzed.
The [case_eq] tactic is similar to [destruct] and [case], except
it records an equality that "remembers" the term being analyzed.
case_eq (f a). intros n n' J3.
case_eq (g n'). intros m m' J4.
(* Now we make use of [J1] and [J2]. The equalities that [case_eq]
gave us will be useful in simplifying those hypotheses. *)
specialize (J1 a). rewrite J3 in J1.
specialize (J2 n'). rewrite J4 in J2.
omega.
Qed.
Lemma compose_is_good_shorter :
forall f g,
Proof.
intros f g J1 J2 a.
(* If we reorganize the proof, we can simply [destruct] all
occurrences of [f _] and [g _] at once, instead of using
[case_eq] and [rewrite]. *)
specialize (J1 a). destruct (f a) as [x y].
specialize (J2 y). destruct (g y) as [x' y'].
omega.
Qed.
Hope that helps,
Brian
- [Coq-Club] Dealing with lets, Benjamin Pierce
- Re: [Coq-Club] Dealing with lets, Gregory Malecha
- Re: [Coq-Club] Dealing with lets, Brian E. Aydemir
Stéphane Lescuyer
- Re: [Coq-Club] Dealing with lets, Benjamin Pierce
