coq-club - Re: [Coq-Club] discriminate JMequalities
chronological Thread
  • To: Damien Pous <Damien.Pous AT inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] discriminate JMequalities
  • Date: Tue, 11 Aug 2009 07:35:32 -0400
Damien Pous wrote:
I am stuck with the following simple goal (even with
`standard' axioms like JMeq_eq or eq_rect_eq...).
Is there a way to solve it ?
Thanks!
Damien
Require Import JMeq.
Inductive B: bool -> Set :=
| ff: B false
| tt: B true.
Goal ~ (JMeq ff tt).
This goal has a lot in common with a class of goals that often turn out unsolvable. The crux of the theorem is in proving the inequality of types. The only effective way I've yet found to prove type inequality is by demonstrating unequal cardinalities. (Proving that a true [Prop] isn't equal to a false [Prop] is a special case of this.)
I'll be curious to see if anyone can give a rigorous argument that your special case isn't provable. I'm guessing that you'd be better off refactoring your higher-level theorems so that they don't depend on proofs of type inequality. Often introducing an extra layer of syntax helps accomplish this goal. You might also try defining a specialized equality for your inductive type, proving that it coincides with the normal equality in the important cases.
