- To: Hai WAN <wan.whyhigh AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] how to proof this?
- Date: Fri, 14 Aug 2009 11:25:14 -0400
Hai WAN wrote:
(* Here are the Coq codes abstracted from a real problem.*)
Section test.
Variable P Q : Prop.
Variable a : P /\ Q.
Variable get : P -> Set.
Variable H0 :
match a with
| conj H0 _ => get H0
end.
Variable b : P.
(* I want to prove this goal, but got stuck. Could any one help? Thanks in advance!*)
Goal (get b).
I expect you need something like proof irrelevance to prove your theorem, like so:
Require Import ProofIrrelevance.
Goal (get b).
rewrite (proof_irrelevance P b (match a with
| conj H _ => H
end));
generalize dependent H0; case a; tauto.
Qed.
Intuitively, the theorem seems false without proof irrelevance, because you have no way of showing that [get] can't return different [Set]s for different proofs of [P]. Alternatively, you could avoid axioms by adding a [Hypothesis] asserting that [get] has this property.
- [Coq-Club] how to proof this?, Hai WAN
- Re: [Coq-Club] how to proof this?, Adam Chlipala
