- To: Tom Harke <harke AT cs.pdx.edu>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Recursive call on a non-recursive argument of constructor
- Date: Tue, 25 Aug 2009 20:16:10 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=pVRTC8p9BfQrT85isJOjb9zdzgD4iA+DVjSfh+8pFI9r+PFus9aKJ3xjx7KgSDFGFk hSOO8FUyWfNNb9EMwpzyULnDk7szwrUYPTxVlB2afb1dIThJEcSeeEp1O4RrqfDhzWlk oVqms+Ouhh4FG+4WZa4y36fvMpVxNkxG4NsFA=
But SpecialObject is Coinductive. I've changed Singleton to be Coinductive and the problem is still there. I need singleton:SpecialObject as opposed to singleton:Object.
Require Import String.
Require Import List.
Section Example.
(*Encoding of the Standard Example MetaModel*)
(*Top*)
CoInductive Top:Set :=
| Build_Top (name:string)
with
Object:Set :=
| Build_Object (features:list Feature)(super:Top)
with
Feature:Set :=
| Build_Feature (superfeat:Top)(featOwningObject:Object)
(*SpecialObject*)
CoInductive SpecialObject:Set :=
| Build_SpecialObject (info:string)(superObj:Object)
with
Singleton:Set :=
Build_Singleton (superSingleton:SpecialObject).
(*Singleton Functions*)
(*Top Functions*)
Definition superSingleton:Singleton -> SpecialObject:=
(fun d:Singleton =>
match d with
| (Build_Singleton sup) =>sup
end).
Coercion superSingleton:Singleton >-> SpecialObject. (*Type Coercion*)
(*Top Functions*)
Definition name:Top -> string:=
(fun d:Top =>
match d with
| (Build_Top elName) => elName
end).
(*Object Functions*)
Definition features:Object -> list Feature:=
(fun d:Object =>
match d with
| (Build_Object feats sup) => feats
end).
Definition super:Object -> Top:=
(fun d:Object =>
match d with
| (Build_Object feats sup) => sup
end).
Coercion super : Object >-> Top. (*Type Coercion*)
(*Feature Functions*)
Definition featOwningObject:Feature -> Object:=
(fun d:Feature =>
match d with
| (Build_Feature sup p) => p
end).
Definition superfeat:Feature -> Top:=
(fun d:Feature =>
match d with
| (Build_Feature sup p) => sup
end).
Coercion superfeat : Feature >-> Top. (*Type Coercion*)
(*SpecialObject Functions.*)
Definition info:SpecialObject -> string:=
(fun d:SpecialObject =>
match d with
| (Build_SpecialObject inf sup) => inf
end).
Definition superObj:SpecialObject -> Object:=
match d with
| (Build_SpecialObject inf sup) => sup
end).
Coercion superObj : SpecialObject >-> Object.
(*Instantiaing a SpecialObject is where the error occurs.*)
(*SpecialObject Metamodel Instance*)
CoFixpoint singleton:SpecialObject :=
Build_Singleton (*Several Levels of Inheritance*)
( (*Supertype of Singleton*)
Build_SpecialObject "someString"
Build_Object (*Supertype of SpecialObject*)
(featureOne::featureTwo::nil) (*List of related Example Feature*)
Build_Top (*Supertype of Object*)
"singleton" (*Name.*)
with
featureOne:Feature :=
Build_Feature
(Build_Top (*Supertype of Feature*)
"featureOne" (*Name.*)
) singleton
) (*Object that owns the Feature *)
with
featureTwo:Feature :=
Build_Feature(
"featureTwo" (*Name.*)
singleton (*Object that owns the Feature*)
End Example.
On Tue, Aug 25, 2009 at 7:04 PM, Tom Harke <harke AT cs.pdx.edu> wrote:
When you use CoFixpoint the result type must be CoInductive.
So, I can get your example to check if I change
to
> CoFixpoint singleton:Object :=
though I don't know if this is what you want.
- [Coq-Club] Re: Recursive call on a non-recursive argument of constructor, Coq User
- Re: [Coq-Club] Re: Recursive call on a non-recursive argument of constructor,
Tom Harke
- Re: [Coq-Club] Re: Recursive call on a non-recursive argument of constructor, Coq User
Tom Harke
