coq-club - [Coq-Club] nat and Datatypes.nat
chronological Thread
  • From: Vincent BENAYOUN <benayoun.vincent AT gmail.com>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] nat and Datatypes.nat
  • Date: Fri, 28 Aug 2009 13:49:07 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=qJXeCs6sn9kHlh6MOnAaLonFF1saDzwDWrxcJR5BfUZj4nyviSEDZqAFRBxi4MZeeH 0sPa4QZZmBDalC+IHA/e5N+kfbpb/OxbIOirGTJQHqbm8Qrf5Acj4c0upR1GjCa/IKg5 D2PWx1u3u1lGSuxFw5q4lvs9W7TfiqZGZVhKY=
Hi,
Does anyone can explain me the signification of the error I get with the below example ?
Thank you in advance,
Vincent
Error message : The term "v" has type "nat" while it is expected to have type
 "Datatypes.nat".
Require Import Coq.Strings.String.
Inductive my_records : Type :=
| My_EmptyRecord : my_records
| My_Record      : forall A B:Type, string -> A -> my_records -> my_records.
Inductive my_restricted_records : Set :=
| Record1  : nat -> my_restricted_records
| Record2  : string -> nat -> my_restricted_records
| Record_other : my_restricted_records.
Definition records_convert (r : my_records) :=
  match r with
    | My_Record nat _ "a" v My_EmptyRecord => Record1 v
    | My_Record string _ "b" b (My_Record nat _ "c" c My_EmptyRecord) => Record2 b c
    | _ => Match0_other (* I need to be exhaustive *)
  end.
