- To: Jeffrey Harris <janglernpl AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Set, Prop, Type
- Date: Wed, 16 Sep 2009 11:13:01 -0400
Jeffrey Harris wrote:
I am aware that having the special rule that members of type Prop can't be used for computation is useful for efficiency and for extracting programs, but I was curious as to whether there was any "purely mathematical" (sorry, I know that's not very precise) reason for having this restriction. The same for Set. More specifically, if the Calculus of Inductive Constructions were implemented solely with sorts Type(0), Type(1), etc., what would be the differences between that implementation and the implementation with Set and Prop?
The important difference of [Prop] vs. [Type] is that [Prop] is impredicative: you may define a [Prop] by quantifying over all [Prop]s. This is a natural thing to do, even in basic theorems about "propositional" logic, like this:
forall P : Prop, P -> ~~P
This statement is itself a [Prop]. If you used [Type] instead of [Prop] everywhere (both in this statement and in the standard library), then the statement would exist at a higher universe level than the universe it quantifies over, so it wouldn't apply to itself.
To me, this justification is separate from the extraction restrictions that you asked about. I think [Prop] (as opposed to impredicative [Set]) exists solely to enable extraction of efficient programs, so there's not so much detective work required about its justification as your question suggests. Impredicativity in a type without [Prop]'s restrictions _is_ inconsistent with some popular classical axioms, so there's another reason.
Also, do you know of any paper which describes the CIC system with the only sorts being the Type(n)'s?
I think I've heard that Agda is purely predicative, but I might be wrong.
- [Coq-Club] Set, Prop, Type, Jeffrey Harris
- Re: [Coq-Club] Set, Prop, Type, Adam Chlipala
- Re: [Coq-Club] Set, Prop, Type, Dan Doel
- Re: [Coq-Club] Set, Prop, Type, Bas Spitters
