- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Contexts in Natural Deduction
- Date: Wed, 16 Sep 2009 18:06:35 +0200
Damien Andrew Tamburri a écrit :
Hello CoqClubbers!
I am having difficulty in including the context for rules in Natural Deduction, within a structure representing Natural Deduction Trees themselves (see attached file).. I keep getting the "The term "In a X" has type "Prop" which is not a (co-)inductive type." error for the last three constructors of type NDTree.. can anyone explain me if and how I can use the construct "if..then..else" in this way? what other context alternatives are there?
many thanks!
Damian Andrew Tamburri
Click less, mail more: Hotmail on the new MSN homepage! <http://go.microsoft.com/?linkid=9677402>
In fact, you should use something like:
(*in the following rule context handling is needed*)
| impi1 : forall (X : list Formula), forall (a b : Formula),
NDTree X b -> NDTree X ( logimp a b )
| impi2 : forall (X : list Formula), forall (a b : Formula), ~In a X ->
I don't know if you want classical or intuitionnistic logic, but I am a little puzzled by your rules:
why don't you use "logimp a logcont" for "lognot a"? (+excluded middle rule)
I think you should also be able to add and remove hypothesis in other rules than ore (andi for example),
or use the same hypothesis for all and define NDTree with
Inductive NDTree (X : list Formula) : Formula -> Set :=
instead of
Inductive NDTree : list Formula -> Formula -> Set :=
which is far more convenient for inversion and other things
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] Contexts in Natural Deduction, Damien Andrew Tamburri
- Re: [Coq-Club] Contexts in Natural Deduction,
Adam Chlipala
- Re: [Coq-Club] Contexts in Natural Deduction, Yves Bertot
- Re: [Coq-Club] Contexts in Natural Deduction, Cedric Auger
Adam Chlipala
