- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: "coq-club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] coq pretty printer
- Date: Thu, 17 Sep 2009 09:03:17 +0200
On Wednesday 16 September 2009 17:04:34 Adam Chlipala wrote: > Bas Spitters wrote: > > Is there a pretty printer for coq sources? > > I would be especially interested in having a tool for indentation. > > > > > > n-1 leading spaces for n open goals. This makes proof scripts easier > > to maintain. > > If your proof scripts are deeply nested enough for you to want to use > indentation to indicate nesting depth, then you should probably be > breaking your proofs into more lemmas that you add as proof hints. ;) > can ever be easy to maintain, regardless of how you display them. I > recommend using automation to prove every theorem with a single tactic. > There are examples of this kind of proof in two projects that I've > worked on recently: > http://ltamer.sourceforge.net/ > http://ynot.cs.harvard.edu/ > ...and I try to explain how to do it in this book-in-progress: > http://adam.chlipala.net/cpdt/ |
- [Coq-Club] coq pretty printer, Bas Spitters
- Re: [Coq-Club] coq pretty printer,
Adam Chlipala
- Re: [Coq-Club] coq pretty printer, Bas Spitters
Adam Chlipala
