- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: Benedikt.AHRENS AT unice.fr
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] concerning Coq XML output
- Date: Mon, 5 Oct 2009 16:40:33 +0200
Hi,
> I have a question concerning the XML output function of Coq:
> I'd like to have a local copy of the Coq standard library in XML. Is
> there a quick way to get this? For example, can I create the XML library
> already when compiling Coq, by patching the make file ?
Explanations are in the Reference Manual (see
e.g. http://coq.inria.fr/doc/Reference-Manual018.html#toc94).
> when trying coqc -xml on some theory file of Coq's standard library
> (here Datatypes.v), I get the error "Name Coq.Init starts with prefix
> "Coq" which is reserved for the Coq library". Since the Coq library is
> precisely what I want, how can I proceed here ?
In this situation, you need to use option -boot (and, for Init, the
extra option -nois) as in "bin/coqtop -boot -xml -nois -compile Datatypes".
Good luck,
Hugo Herbelin
- [Coq-Club] concerning Coq XML output, Benedikt . AHRENS
- Re: [Coq-Club] concerning Coq XML output, Hugo Herbelin
