coq-club - Re: [Coq-Club] Complexity of proof terms generated by the inversion tactic
chronological Thread
  • To: Robin Green <greenrd AT greenrd.org>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Complexity of proof terms generated by the inversion tactic
  • Date: Sun, 25 Oct 2009 16:40:25 -0400 (EDT)
On Sat, 4 Jul 2009, Robin Green wrote:
If I use Proof. ... Defined. to build a term, and I use inversion in
the proof, the generated proof term can be quite complicated. If I use
"info inversion" to see what tactics are being used in that proof step,
the output is quite long. So it looks like it would be a lot of work
for me to understand how the inversion tactic works in this particular
situation.
Is there any way, apart from using the simple inversion tactic, to make
the proof terms less complicated for a proof involving inversion? Or at
least, in some sense easier to work with in a subsequent proof
involving that definition?
I'm not sure why no one mentioned this, but you can write:
Derive Inversion MyInversionLemma ...
to automatically generate a new lemma called "MyInversionLemma". Then you can use this lemma in your proof.
Check the manual for how to use "Derive Inversion".
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
