- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: roconnor AT theorem.ca
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Generaling parameteric Fixpoint parameters
- Date: Thu, 29 Oct 2009 03:40:04 +0100
> It would be better to (eventually) have it on by default because we want to
> make avaiable fixpoints with higher order uniform parameters from people who
> haven't even though about others reusing their work.
Indeed, that's the idea. But even if its on by default it still
facilitates backward compatibility : you can have your own Compat82.v
file that just contains 'Automatic Generalization off' and you only
need to import it in your old projects.
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] Generaling parameteric Fixpoint parameters, roconnor
- Re: [Coq-Club] Generaling parameteric Fixpoint parameters,
Stéphane Lescuyer
roconnor
- Re: [Coq-Club] Generaling parameteric Fixpoint parameters, Stéphane Lescuyer
roconnor
Stéphane Lescuyer
