coq-club - Re: [Coq-Club] information
chronological Thread
  • From: Benjamin Werner <(e6fa90e88c%hidden_head%e6fa90e88c)ben(e6fa90e88c%hidden_at%e6fa90e88c)benjamin.werner.name(e6fa90e88c%hidden_end%e6fa90e88c)>
  • To: Andrea Poles <(e6fa90e88c%hidden_head%e6fa90e88c)evilpuchu(e6fa90e88c%hidden_at%e6fa90e88c)gmail.com(e6fa90e88c%hidden_end%e6fa90e88c)>
  • Cc: (e6fa90e88c%hidden_head%e6fa90e88c)coq-club(e6fa90e88c%hidden_at%e6fa90e88c)pauillac.inria.fr(e6fa90e88c%hidden_end%e6fa90e88c)
  • Subject: Re: [Coq-Club] information
  • Date: Wed, 16 Dec 2009 12:37:58 +0100
Hi,
Le 16 déc. 2009 à 12:22, Andrea Poles a écrit :
Fixpoint divide (a b:nat) {struct b} : bool :=
match lwt b a with
true => false
match a with
 O => false
 match b with
   a => true
   | _ => divide a minus(b a)
   end
 end
end.
Divide should return true if b%a =0 false otherwise, but the Coqide
returns "Error: This clause is redundant." on this line:
   | _ => divide a minus(b a).
You are misunderstanding pattern-matching in the clause
a => true.
Here you want to test equality between a and b. You shoud use
a function testing equality between natural numbers. Like dec_eq_nat
defined in the library Peano_dec.
Here, the clause a => true matches all natural numbers; the fact that
there is another variable named a is irrelevant.
This way to handle pattern-matching is not specific to Coq but shared by
most functional languages (ML, Haskell, etc).
Benjamin
