- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Babak Moazzez <babakmoazzez AT yahoo.com>
- Cc: coq-club AT pauillac.inria.fr, CHA Reeseo <reeseo AT formal.korea.ac.kr>
- Subject: Re: [Coq-Club] A Question
- Date: Thu, 24 Dec 2009 07:53:07 +0100
Hi,
what do you precisely mean by "adding two lists together" ?
Do you mean "appending" ?
In this case, it is the "app" function from library List,
Fixpoint app {A:Type}(l l' : list A) : list A :=
match l with nil => l'
| a::l'' => a::(app l'' l')
end.
If you mean "mapping addition elementwise", it is still a structural
recursion on lists.
Fixpoint eltwise (l l':list nat) : list nat :=
match l,l' with
nil,l' => l'
| l,nil => l
| (a::l),(b::l') => (a+b)::(eltwise l l')
end.
Anyway, as CHA Reeseo says, if you need to use a comparison in an if-then-else,
you need either a boolean function or a function returning a value of type
sumbool. For instance, with natural number, you may use :
beq_nat : nat -> nat -> bool
or
eq_nat_dec : forall n m:nat, {n=m}+{n <> m}.
Pierre
Quoting Babak Moazzez
<babakmoazzez AT yahoo.com>:
Hi.
I am trying to define a function in Coq that adds two lists together. for this purpose , I need to use a structure which is very familiar in any programming language:
if (p=q) then do ....
but in Coq I cannot use this since (p=q) is not a boolean value but just a proposition which needs to be proved if it is true.
Can anybody tell me what to do?
Thanks.
Babak Moazzez
School of Mathematics and Statistics
Carleton University
Address:
Room 4356, Herzberg Building
Carleton University
1125 Colonel By Drive
Ottawa, ON K1S 5B6
Canada
Web: www.math.carleton.ca/~bmoazzez
Tel: 613 520 2600 Ext. 8789
Email:
bmoazzez AT math.carleton.ca
or
New Email names for you!
Get the Email name you've always wanted on the new @ymail and @rocketmail.
Hurry before someone else does!
http://mail.promotions.yahoo.com/newdomains/aa/
- [Coq-Club] Final Call for Participation: TLDI'10, Andrew Kennedy
- [Coq-Club] A Question,
Babak Moazzez
- Re: [Coq-Club] A Question, CHA Reeseo
- Re: [Coq-Club] A Question, Pierre Casteran
AUGER Cédric
- Re: [Coq-Club] A Question, Vincent Siles
AUGER Cédric
Babak Moazzez
