- From: Недзельский Михаил <MichaelNedzelsky AT yandex.ru>
- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] a "classical versus intuitionistic" question
- Date: Sun, 27 Dec 2009 01:36:46 +0300
Vladimir Voevodsky пишет:
A question: where is a mistake in the following reasoning?
1. assume that "classical Peano arithmetics is inconsistent" i.e. there is a
finite sequence of deductions in the corresponding theory which constitutes a proof of
False (=not True),
2. using double negation trick this sequence can be translated into a
sequence of deductions in a strongly normalizing intuitionistic type system
with inductive N and inductive empty type which will create an inhabitant of
(not not not True),
3. inhabitance of (not not not True) is equivalent to the inhabitance of the
empty type,
4. strong normalization implies that the empty type is not inhabited.
Therefore, "classical Peano arithmetics" is consistent.
Vladimir.
It seems that in order to formalize given reasoning you need a formal system with strength >= strength of PA (especially step 4). If PA is inconsistent, then this formal system is also inconsistent, so both "PA is consistent" and "PA is inconsistent" will be theorems in this formal system.
Michael Nedzelsky
- [Coq-Club] JFLA 2010: appel participation, Micaela Mayero
- [Coq-Club] a "classical versus intuitionistic" question,
Vladimir Voevodsky
- Re: [Coq-Club] a "classical versus intuitionistic" question, Недзельский Михаил
Vladimir Voevodsky
