- To: coq-club AT inria.fr
- Cc: Christian Doczkal <doczkal AT ps.uni-sb.de>
- Subject: Re: [Coq-Club] Programming custom Tactics
- Date: Wed, 6 Jan 2010 17:43:30 +0000
On Wednesday 06 January 2010 16:14:23 Christian Doczkal wrote:
> (* Sorry for my previous incomplete message! *)
> Hello Everyone
> >From what I read so far, there seem to be a number of different ways to
> extend Coq with additional tactics.
> 1. Code it directly in Ltac
> 2. Use reflection and code it directly in Gallina
> 3. Code an external tactic and call it using "external" using XML
> for communication
> 4. Coding the tactic directly into Coq at the OCaml level
> 1 and 2 are covered to some extent in the Coq Reference Manual and in
> Adam Chlipala's cpdt notes. Is there any documentation available how to
> get started with coding tactics using variant 3 and/or 4? (Besides
> browsing the Coq source files)
> Does someone have short nicely documented .ml file of a simple tactic
> for demonstration purposes?
I started writing OCaml tactics a while ago and could not find any
documentation besides reading the source code. The best approach I found was
to find a currently implemented Coq tactic that does something similar to
what
you want your tactic to do, search the source code to find the code that
implements that tactic and then use your knowledge of how that tactic works
to
figure out what the functions used in the code do. I'd be delighted to know
if
there was an easier way than this.
If you want to write your own plugin, have a look at the "plugins/quote"
folder. The code for plugin is quite short so should give you an idea for how
to get started.
Good luck,
Sean
- [Coq-Club] Programming custom Tactics, Christian Doczkal
- <Possible follow-ups>
Christian Doczkal
- Re: [Coq-Club] Programming custom Tactics, Sean Wilson
Christian Doczkal
Pierre Corbineau
Christian Doczkal
- Re: [Coq-Club] Programming custom Tactics, Pierre Corbineau
- Re: [Coq-Club] Programming custom Tactics, Matthieu Sozeau
Christian Doczkal
- Re: [Coq-Club] Programming custom Tactics, Vladimir Komendantsky
Pierre Corbineau
Christian Doczkal
