- To: Gyesik Lee <leegys AT gmail.com>
- Cc: Vladimir Voevodsky <vladimir AT ias.edu>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Positive occurrences below a "match"
- Date: Mon, 18 Jan 2010 07:13:49 -0500
1. In this particular example you would get (if it worked) tata (n) =
emptytype since what you define is a family over nat whose fiber over n is
freely generated by the constructor (nat^n -> X) -> X and emptytype is the
"initial algebra " for these constructors for any n\ge 0.
2. it does not work because the left hand side of the constructor is not a
strictly positive type expression of tata. Strict positivity is a syntactic
condition.The expression toto n (tata n) is not strictly positive in (tata
n). For each individual n:nat of the form S.....S 0 the expression toto n
(tata n) normalizes to (nat->(nat->...(nat-> tata n)..)) which is strictly
positive but for an "abstract" n:nat it is not strictly positive.
3. To make this particular constructors work you may, for example, define,
inductively a function nat_n:nat -> Type whose value on n is nat^n (may be in
two steps first a function Prod: Type -> Type -> Type as Inductive Prod(X
Y:Type):Type := X -> Y -> Prod X Y. and then nat_n by the rule nat_n(S
n)=Prod nat nat_n(n)). Then you can write your constructor sem as (nat_n n ->
tata n) -> tata n .
V.
On Jan 18, 2010, at 5:48 AM, Gyesik Lee wrote:
> Dear coq-users,
> I have encountered a problem with positivity condition when I was
> trying to define an inductive type.
> Here is a simplified version:
> Fixpoint toto (n : nat) (X : Type) : Type :=
> match n with
> | 0 => X
> | S n => nat -> toto n X
> end.
> Inductive tata (n : nat) : Type :=
> sem : toto n (tata n) -> tata n.
> Error: Non strictly positive occurrence of "tata" in
> "toto n (tata n) -> tata n".
> You can easily see that the positivity condition is satisfied.
> Is this a Coq restriction? If yes, is there a way to get around it?
> Gyesik
- [Coq-Club] Positive occurrences below a "match", Gyesik Lee
- Re: [Coq-Club] Positive occurrences below a "match", Vladimir Voevodsky
- Re: [Coq-Club] Positive occurrences below a "match", Matthieu Sozeau
