- To: AUGER <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Making universe inconsistency only using "Require"
- Date: Tue, 19 Jan 2010 09:24:54 -0500 (EST)
On Tue, 19 Jan 2010, AUGER wrote:
Hi all,
I found a coq feature which doesn't seem natural:
coqc base.v; coqc baseA.v; coqc baseB.v
and then try to compile baseC.v, it will fail
(hopefully, since we morally defined the set of all sets),
but when we are used to functionnal programing, we don't expect
such an error, as something compiled can always be used...
Each module comes with a set of global universe constraints. When you combine two modules their sets of universe constraints are unioned and my become inconsistent.
I don't find this very different than trying to compile together two Haskell modules that both define class instances over the same type. Again we have each module with some sort of global constraint. When the global constraints merge there can be conflicts. (Granted in GHC an error only occurs when you try to use the overlapping instances.)
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- Re: [Coq-Club] Why do we need modules anyway?, (continued)
Adam Chlipala
Stéphane Lescuyer
- Re: [Coq-Club] Why do we need modules anyway?, Chris Dams
AUGER
Roman Beslik
- Re: [Coq-Club] Why do we need modules anyway?, Stéphane Lescuyer
Bas Spitters
- [Coq-Club] Making universe inconsistency only using "Require",
AUGER
- Re: [Coq-Club] Making universe inconsistency only using "Require", Vladimir Voevodsky
- Re: [Coq-Club] Making universe inconsistency only using "Require", roconnor
AUGER
Roman Beslik
Stéphane Lescuyer
Adam Chlipala
