coq-club - Re: [Coq-Club] Ltac-matching a "match..with"
chronological Thread
  • To: Eugene Kirpichov <ekirpichov AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ltac-matching a "match..with"
  • Date: Fri, 29 Jan 2010 17:05:14 -0500
Eugene Kirpichov wrote:
2010/1/30 Adam
Chlipala<adam AT chlipala.net>:
Suppose I'm proving the following theorem.
Theorem t : forall n, match n with | O =>    O | S x =>    S x end = n.
   intros n.
Thanks, but the following statement also doesn't work.
   match goal with [ |- match ?n with | O =>  _ | S _ =>  _ end ] =>
destruct n end.
Your goal isn't a [match]. Rather, your goal is an equality whose lefthand side is such a [match]. You can add [= _] to your pattern or use a [context] pattern.
By the way, I still don't understand why Coq needs type information in
this case, if Ltac is untyped and operates over syntax...
It's clear if you look at Coq's kernel representation of Gallina programs, where a [match] contains an array of cases, one per constructor, regardless of which patterns were entered at the source level. I agree that this isn't very convenient from the user's perspective.
