coq-club - Re: [Coq-Club] How to understand "Declare" in a module?
chronological Thread
  • To: Hai WAN <wan.whyhigh AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to understand "Declare" in a module?
  • Date: Tue, 02 Feb 2010 07:58:58 -0500
Hai WAN wrote:
What does it mean by "Declare Module f : F_sig.". Does it mean that we declare a module f of signiture F_sig? Is it similar to "Variable f : F_sig"?
I always thought of [Declare Module] as a command that only makes sense inside signatures. I'm surprised that it's allowed inside a module definition; I certainly don't yet see a reason to use it that way.
I then wrote the following codes, which make totally confused.
Goal False.
apply F_mod.ff.
Qed.
In cases like this, you can always use [Print Assumptions] to see whether your proof really depends on some hidden axiom. (In this case, it does.)
Theorem bad : False.
apply F_mod.ff.
Qed.
Print Assumptions bad.
(* Coq says: *)
Axioms:
F_mod.f.F : False
