- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] An interesting example using Heq
- Date: Thu, 4 Feb 2010 12:53:53 -0000
Hi,
I received an example from Benedikt Ahrens and he
asked whether I can simplify his proof using Heq.
That example was interesting to me because I
didn't have this kind of example in mind when I developed Heq, but Heq
helped.
I wonder whether there is a direct simple proof, or
Heq is particularly useful in this case.
Here is the example.
Require Import FunctionalExtensionality.
Set Implicit Arguments. Record Cat_data : Type := mkcat_data
{ obj :> Type; mor : forall a b : obj, Type; id : forall a:obj, mor a a; comp : forall a b c: obj, mor a b -> mor b c -> mor a c }. Record Functor_data (C1 C2 : Cat_data) : Type :=
mkfunctor_data
{ map_o :> C1 -> C2; map_m : forall (a b : obj C1), mor C1 a b -> mor C2 (map_o a) (map_o b) }. Goal forall C1 C2 mo mm,
mkfunctor_data C1 C2 (fun a => mo a) (fun a b f => mm a b f) = mkfunctor_data C1 C2 mo mm. =============================================
We want to prove the above goal using
But, simple rewriting does not work because the
fourth argument of mkfunctor_data depends on its third argument.
I proved it in the following way using
Heq.
Proof.
Require Import Heq.
intros.
replace (fun a b f => mm a b f) with mm by (repeat (apply @functional_extensionality_dep; intro); auto). set (mo_eta := fun a => mo a) in *. HreflI mm at 2. revert mm. change mo_eta with (fun a => mo a). clear mo_eta. hrewrite <- (eta_expansion mo). intros. Hclear. reflexivity. Qed. ============================================= Best,
Chung-Kil Hur
- [Coq-Club] An interesting example using Heq, Chung Kil Hur
- Re: [Coq-Club] An interesting example using Heq,
Adam Chlipala
- Re: [Coq-Club] An interesting example using Heq, Chung Kil Hur
Adam Chlipala
