coq-club - Re: [Coq-Club] Coq pattern matching going crazy on me -> looks like a bug.
chronological Thread
  • To: Chris Dams <chris.dams.nl AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq pattern matching going crazy on me -> looks like a bug.
  • Date: Sun, 14 Feb 2010 19:14:03 +0100
Hi,
> In the final Check command Coq says that the 3 in the first branch of
> the match is wrong (it is of course right about that!).
> It says:
> Error: In environment
> H2 : test int 5
> t''' : type
> The term "3" has type "nat" while it is expected to have type
>  "forall t'' : type, ref t'' = t'' -> False".
> However, the type that Coq proposes is not right either!
> The pattern of this branch is test1 t''' and that is of type  test (ref
> t''') 3.
> Hence in this case, to obtain the return type we should do the
> substitutions t' -> ref t''' and v'' -> 3.
> Hence the type that should be expected becomes
>      forall t'': type,
>      ref t''' = t'' ->
>      False
> However, Coq is requesting the type with t''' replaced with t''!
This is indeed a bug. Probably due to the same reason as bug 2193
(http://coq.inria.fr/bugs/show_bug.cgi?id=2193).
The development versions behave well but unfortunately not the
8.2pl1. Sorry.
Hugo Herbelin
