- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] difficulties with rewrite
- Date: Wed, 17 Feb 2010 11:59:17 +0100
Hello,
I've got some problem trying to use rewrite in some deep occurrence of a subterm.
In the following example (attached file), the rewrite fails, whilst an iterated application
of op_m succeeds. What is failing in the class declaration for having a "rewrite H" ok ?
Pierre
Require Import Relations.
Require Import Setoid Morphisms.
Class SemiGroup (A:Type) :={
_eq : A -> A -> Prop;
op : A -> A -> A;
neutral : A ;
op_equiv :> Equivalence _eq;
op_comm : forall x y:A, _eq (op x y) (op y x);
op_assoc : forall x y z:A, _eq (op x (op y z)) (op (op x y) z);
n_def : forall x, _eq (op neutral x) x;
op_m : Morphism (_eq ==> _eq ==> _eq) op
Lemma Essai `(SemiGroup A) : forall a b c d e, _eq a b ->
_eq (op (op (op a c) d) e)
(op (op (op b c) d) e).
Proof.
intros A SG a b c d e H.
rewrite H. (* fails *)
repeat apply op_m; try reflexivity;assumption.
Qed.
- [Coq-Club] difficulties with rewrite, Pierre Casteran
- Re: [Coq-Club] difficulties with rewrite, Stéphane Lescuyer
