- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: Chris Dams <chris.dams.nl AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we need modules anyway?
- Date: Thu, 25 Feb 2010 15:21:41 -0800
I'm glad Adam mentioned ascription, because I have a question about
it. IIUC, a key benefit of a module system is ascription, which
restricts implementation details.
I want to (morally, metatheoretically) justify the use of the following
axiom outside of the module body that defines [MyType].
Axiom setoid_eq_eq: forall (a b:MyType), a == b -> a = b.
The equivalence relation [==] is also defined in the same module as
[MyType], and all consumers of elements of MyType are either
1. setoid morphisms, or
2. hidden by ascription
Can [setoid_eq_eq] be justified on the grounds that points 1 and 2
so severely restrict the contexts that can examine a and b that [==]
is the same as [=]?
On Sat, Jan 16, 2010 at 07:23:12AM -0500, Adam Chlipala wrote:
> Chris Dams wrote:
>> It seems writing records like list_type is about the same as writing
>> Modules. Moreover, they are first class citizens in the Coq language,
>> being Inductives with some extra destructor names for convenience. So,
>> why was the basic Coq language polluted with the seemingly useless
>> concept of modules?
> There are certainly ways to make Coq's module system more useful, but I
> wouldn't call it useless. You get the automatic support for "subtyping"
> that comes from module signature ascription. It's also useful to work
> with second-class constructs in many cases; they are intrinsically
> easier to understand, because the reader knows you can do fewer things
> with them. Finally, there are commands like [Import] that only work on
> modules, though a similar command could certainly be implemented for
> records.
Tom Harke
- Re: [Coq-Club] Why do we need modules anyway?, harke
