- From: "Zhoulai.FU AT X.org" <zhoulai.fu AT polytechnique.org>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Beginner's question: how to prove m+n = n+m
- Date: Mon, 1 Mar 2010 16:25:08 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=Q6439R/LhvqDOZj9tKPJKpDgnShczli2eddM2WeGA/zvcQISZErBVxhR75d2SKbK+Z qfdDrmw63eIimFNQQuKbhfCR2HrCqW0GKUJVM6knxy4G+W9jNXt+n7FiQRTI1FI+EPqf X0/zUcxGz76eAUhKBIbcIZwNcuKOUXpn8vYp4=
Hello Guillaume,
Thank you for your answer.
I agree that it is not a hard work if we introduce a lemma as you said. However to do that, if I understand well , you may probably have to use something like this
[rewrite] [lemma_name]
But the "rewrite" learned till now does not have that syntax. It can only rewrite
syntactically something following a rule indicated by a hypothesis.
Thus, finally my question turns to:
"Can we work around more primitively with
-simpl. reflexivity. intros. Case. Eval.
-induction
-rewrite with the syntax: [rewrite] [<-]/[->] [hypothesis]
or can we fullfil the case "n=S n', m = S m'" in the follwing part?
Theorem plus_comm : forall n m : nat,
plus n m = plus m n.
Proof.
intros n m.
induction n as [|n'].
induction m as [|m'].
Case "n=0 m=0".
reflexivity.
Case "n=S n' m=0'".
simpl. rewrite <- IHm'. simpl. reflexivity.
Case "n=Sn' m=0".
simpl. rewrite -> IHn'. reflexivity.
Case"n=Sn' m= S m'".
(*Can we fullfil this case with a primitive way????*)
Admitted.
I hope it's clear. Thanks in advance.
Z.
On Mon, Mar 1, 2010 at 12:49 PM, gallais @ EnsL <guillaume.allais AT ens-lyon.fr> wrote:
Hi,
You should just try to prove it by induction : the generated goals are quite easy to prove (even for a beginner) once you know that there exists a lemma `plus_n_Sm` stating that `forall n m : nat, S (n + m) = n + S m`.
You can try to prove plus_n_Sm as a sublemma (the induction proof is also quite easy) and you will be able to proove plus_comm using only intro, induction, reflexivity, rewrite and simpl.
Cheers,
guillaume
On 1 March 2010 12:36, Zhoulai.FU AT X.org <zhoulai.fu AT polytechnique.org> wrote:How can I prove it with only the several keywords that learned so far: InductionOn Mon, Mar 1, 2010 at 11:58 AM, Adam Koprowski <adam.koprowski AT gmail.com> wrote:
On Mon, Mar 1, 2010 at 11:53, <zell08v AT orange.fr> wrote:Hello,
I am a total beginner on Coq. Here is an exercise from the introduction cours
of Pierce. To prove:
Proof.
(* FILL IN HERE *) Admitted.
How can I prove it with only the several keywords that leaarned so far:
simpl. reflexivity. rewrite. intros. Case. Eval.Indeed, as the proof goes by induction, you will have to extend this list with the [induction] tactic.
Thanks. You are right. I had forgetten [induction]. In fact, my question should have been:I mean I still hope to know the answer with this extended list:) Thanks in advance.
Zhoulai FU
INRIA Rennes - Bretagne Atlantique
Campus Universitaire de Beaulieu
35042 RENNES Cedex - FRANCE
- [Coq-Club] Beginner's question: how to prove m+n = n+m, zell08v
- Re: [Coq-Club] Beginner's question: how to prove m+n = n+m,
Adam Koprowski
Zhoulai.FU AT X.org
gallais @ EnsL
- Re: [Coq-Club] Beginner's question: how to prove m+n = n+m, Zhoulai.FU AT X.org
- Re: [Coq-Club] Beginner's question: how to prove m+n = n+m, Guilhem Moulin
- Re: [Coq-Club] Beginner's question: how to prove m+n = n+m, Adam Koprowski
gallais @ EnsL
Zhoulai.FU AT X.org
- Re: [Coq-Club] Beginner's question: how to prove m+n = n+m, Jean-Marc Notin
Adam Koprowski
