- To: coq-club AT inria.fr
- Subject: [Coq-Club] Problem with terms differing in their obligations
- Date: Mon, 1 Mar 2010 20:37:59 +0000
Hi all,
I am stuck, with a goal:
<< p :> s >> <~~>* << p :> s >>
which I want to prove with
apply Same.
where Same is defined as:
:= Same : forall (s : Sequence patchUniverse from to contains),
(<<s>> <~~>* <<s>>)
Unfortunately, this fails with
Error: Impossible to unify "p :> s" with "p :> s".
as the two (p :> s) terms are not as identical as they appear. With
notations off, they differ in the obligation functions that they
contain:
"Cons p s
(EnlargeTransitiveCommuteRelation2_obligation_4 patchUniverse from mid to
contains contains' p s s pNotInTail containsOK)
(EnlargeTransitiveCommuteRelation2_obligation_5 patchUniverse from mid to
(EnlargeTransitiveCommuteRelation2_obligation_6 patchUniverse from mid to
contains contains' p s s pNotInTail containsOK)" with
"Cons p s
(EnlargeTransitiveCommuteRelation2_obligation_1 patchUniverse from mid to
(EnlargeTransitiveCommuteRelation2_obligation_2 patchUniverse from mid to
(EnlargeTransitiveCommuteRelation2_obligation_3 patchUniverse from mid to
contains contains' p s s pNotInTail containsOK)".
I can see why it doesn't work, but I can't see how I can reasonably
solve it. Has anyone got any suggestions please? I've attached the
cut-down example.
Thanks
Ian
Module Export patch_universes.
Require Import Program.
Require Export FSets.
Require Export FSetDecide.
Require Export FSetProperties.
Require Import FSetWeakList.
Parameter Name : Set.
Axiom eq_Name_dec : forall (n : Name) (o : Name), {n = o} + {n <> o}.
Inductive Sign : Set
:= Positive | Negative.
Inductive SignedName : Set
:= MkSignedName : forall (s : Sign)
(n : Name),
SignedName.
Lemma eq_SignedName_dec : forall (sn1 : SignedName) (sn2 : SignedName),
{sn1 = sn2} + {sn1 <> sn2}.
Proof with auto.
intros.
destruct sn1;
destruct s;
destruct sn2;
destruct s.
destruct (eq_Name_dec n n0).
left.
f_equal...
right.
intro.
inversion H...
right.
intro.
inversion H...
right.
intro.
inversion H...
left.
f_equal...
right.
intro.
inversion H...
Qed.
Module DecidableName.
Definition t := Name.
Definition eq := @eq Name.
Definition eq_refl := @refl_equal Name.
Definition eq_sym := @sym_eq Name.
Definition eq_trans := @trans_eq Name.
Definition eq_dec := eq_Name_dec.
End DecidableName.
Module NameSetMod := Make(DecidableName).
Notation NameSet := (NameSetMod.t).
Notation NameSetEqual := (NameSetMod.Equal).
Module NameSetDec := WDecide (NameSetMod).
Module DecidableSignedName.
Definition t := SignedName.
Definition eq := @eq SignedName.
Definition eq_refl := @refl_equal SignedName.
Definition eq_sym := @sym_eq SignedName.
Definition eq_trans := @trans_eq SignedName.
Definition eq_dec := eq_SignedName_dec.
End DecidableSignedName.
Module SignedNameSetMod := Make(DecidableSignedName).
Notation SignedNameSet := (SignedNameSetMod.t).
Notation SignedNameSetIn := (SignedNameSetMod.In).
Notation SignedNameSetAdd := (SignedNameSetMod.add).
Notation SignedNameSetRemove := (SignedNameSetMod.remove).
Notation SignedNameSetEqual := (SignedNameSetMod.Equal).
Notation SignedNameSetEqRefl := (SignedNameSetMod.eq_refl).
Record PatchUniverse : Type := mkPatchUniverse {
pu_type : (NameSet -> NameSet -> Set);
pu_nameOf : forall {from to : NameSet}, pu_type from to -> SignedName
Inductive Sequence (patchUniverse : PatchUniverse)
(from to : NameSet)
(contains : SignedNameSet)
: Type
:= Nil : forall (fromEqTo : NameSetEqual from to)
(containsNothing : SignedNameSetEqual contains
SignedNameSetMod.empty),
| Cons : forall {from' mid : NameSet}
{qsContains : SignedNameSet}
(p : (pu_type patchUniverse) from' mid)
(qs : Sequence patchUniverse mid to qsContains)
(fromOK : NameSetEqual from from')
(notAlreadyThere : ~ SignedNameSetIn (pu_nameOf _ p)
qsContains)
(containsOK : SignedNameSetEqual
contains
(SignedNameSetAdd (pu_nameOf _ p)
qsContains)),
Sequence patchUniverse from to contains.
Implicit Arguments Nil [patchUniverse from to contains].
Implicit Arguments Cons [patchUniverse from to contains from' mid qsContains].
Notation "s :> t" := (Cons s t _ _ _)
(at level 60, right associativity).
Notation "[]" := (Nil _ _)
(no associativity).
(* This is an over-simplified dummy definition. We only care
about the transitive relation below. *)
Reserved Notation "<< p >> <~~> << q >>"
(at level 60, no associativity).
Inductive CommuteRelates {patchUniverse : PatchUniverse}
{from to : NameSet}
{contains : SignedNameSet}
-> Sequence patchUniverse from to contains
-> Prop
:= SwapCheat : forall (ps qs : Sequence patchUniverse from to contains),
(<<ps>> <~~> <<qs>>)
where "<< p >> <~~> << q >>" := (@CommuteRelates _ _ _ _ p q).
Reserved Notation "<< p >> <~~>* << q >>"
Inductive TransitiveCommuteRelates {patchUniverse : PatchUniverse}
{from to : NameSet}
-> Prop
(<<s>> <~~>* <<s>>)
| Swap : forall {s : Sequence patchUniverse from to contains}
{t : Sequence patchUniverse from to contains}
{u : Sequence patchUniverse from to contains},
(<<s>> <~~> <<t>>)
-> (<<t>> <~~>* <<u>>)
-> (<<s>> <~~>* <<u>>)
where "<< p >> <~~>* << q >>" := (@TransitiveCommuteRelates _ _ _ _ p q).
Program Lemma EnlargeTransitiveCommuteRelation1 :
forall {patchUniverse : PatchUniverse}
{from mid to : NameSet}
{contains contains' : SignedNameSet}
{p : (pu_type patchUniverse) from mid}
{qs rs : Sequence patchUniverse mid to contains'}
(pNotInTail : ~ SignedNameSetIn (pu_nameOf _ p) contains')
contains
(SignedNameSetAdd
(pu_nameOf _ p)
contains')),
(<<qs>> <~~>* <<rs>>)
-> (<< (Cons p qs (NameSetMod.eq_refl _) pNotInTail containsOK) >> <~~>*
<< (Cons p rs (NameSetMod.eq_refl _) pNotInTail containsOK) >>).
Proof with auto.
intros patchUniverse from mid to contains contains' p qs rs ? ? qs_rs.
induction qs_rs.
apply Same.
admit. (* This isn't the interesting branch, so cheat *)
Qed.
Program Definition EnlargeTransitiveCommuteRelation2 :
contains
(SignedNameSetAdd
(pu_nameOf _ p)
contains'))
(pqs := (p :> qs) : Sequence patchUniverse from to contains)
(prs := (p :> rs) : Sequence patchUniverse from to contains),
-> (<< pqs >> <~~>* << prs >>) := _.
Next Obligation.
NameSetDec.fsetdec.
Qed.
Next Obligation.
NameSetDec.fsetdec.
Qed.
Next Obligation.
induction H.
apply Same.
Last line fails.
Goal: << p :> s >> <~~>* << p :> s >>
Fails with: Error: Impossible to unify "p :> s" with "p :> s".
Same is defined as:
(<<s>> <~~>* <<s>>)
With notations off, the error is:
"Cons p s
"Cons p s
- [Coq-Club] Problem with terms differing in their obligations, Ian Lynagh
- Re: [Coq-Club] Problem with terms differing in their obligations, Adam Koprowski
