- To: ben <Benedikt.Ahrens AT unice.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] case distinction and Program
- Date: Wed, 3 Mar 2010 14:05:23 -0500
Hi Benedikt,
Le 3 mars 10 à 11:57, ben a écrit :
Hello,
I am working on a formalisation of the category Delta, i.e. sets of
naturals smaller than a given natural, and weakly monotone functions
between them.
Given two monotone functions, I can place them side by side. This should
again give a monotone functions between the sums of sources and targets,
resp.
The last definition of the theory on the bottom is my attempt to define
this "sum" of functions. It is done using Program, since there are a lot
of proof obligations involved.
Unfortunately I don't succeed in solving the last obligation
(monotonicity of the sum of functions), where I would like to distinct
two cases (c.f. the code).
How could I solve this last obligation ?
<snip/>
Variables m m' n n': nat.
Variable f: HomDelta n n'.
Variable g: HomDelta m m'.
Program Definition plus_morphism : HomDelta (n + m) (n' + m') :=
fun i => match le_lt_dec n i with
| right _ => f i
| left _ => n' + g (i - n)
end.
Next Obligation.
Proof. apply cod_wd2. Defined.
Next Obligation.
Proof. apply lt_minus.
rewrite plus_comm.
apply (proj2_sig i).
auto.
Defined.
Next Obligation.
Proof. apply lt_plus_left.
apply cod_wd.
Defined.
Next Obligation.
Proof. unfold monotone. intros x y H.
(* case (le_lt_dec n x). *)
(* would be what i'd like to have *)
You have a problem of dependency here. As the obligations have types
mentionning proofs of [x = le_lt_dec .. ..], you cannot generalize le_lt_dec
here. One way to eliminate this dependency is to unfold the obligations,
(using [autounfold with plus_morphism in *] in 8.3) or to avoid this
unnecessary dependency using an [if then else] instead of a [match] in
the definition. When matching [le_lt_dec n i], you don't actually need to
keep an equality between the call and the branches patterns as all the
important logical information is kept in the result of [le_lt_dec n i].
Another way to deactivate the generation of this equality is to write
[match le_lt_dec n i return _] which forces the inference of the predicate
in the usual way.
Hope this helps,
-- Matthieu
- [Coq-Club] case distinction and Program, ben
- Re: [Coq-Club] case distinction and Program, Matthieu Sozeau
