- To: Z <zell08v AT orange.fr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] "Recursive definiton ill-formed"?
- Date: Sun, 07 Mar 2010 11:55:10 -0500
Z wrote:
Could you please tell me why this program has a syntax error with this message
"Recursive definiton ill-formed"? Maybe the syntax of recursive function in Coq is not like
ML etc?
Thanks in advance.
Fixpoint oddmembers (l:natlist) : natlist :=
match l with
| nil =>nil
| h :: t =>
match h with
| 0 => oddmembers t
| 1 => 1 :: (oddmembers t)
| S (S h') => oddmembers (h' :: t)
end
end.
Your definition isn't obviously terminating; that is, the simple rule of primitive recursion doesn't show that it always terminates. All Coq programs must terminate. Therefore, to get Coq to accept your definition, you would have to use an explicit termination argument.
I believe this trouble is easy to avoid in your specific example, by using an auxiliary recursive function for deciding evenness. (This would even lead to cleaner code that's easier to understand, which is not the usual case when someone hits a problem with termination checking. ;])
- [Coq-Club] "Recursive definiton ill-formed"?, Z
- Re: [Coq-Club] "Recursive definiton ill-formed"?, Adam Chlipala
- Re: [Coq-Club] "Recursive definiton ill-formed"?, Pierre Casteran
