- Cc: coq-club AT inria.fr
- Subject: [Coq-Club] Re: [Reserved Notation] and [Record]
- Date: Sun, 14 Mar 2010 22:09:18 +0000
- Cancel-lock: sha1:YZ/wO2cySIJuN6AIEK0YdW3Er/E=
- Envelope-to: coq-club AT inria.fr
- Newsgroups: gmane.science.mathematics.logic.coq.club
- Organization: Myself
- Posted-to: gmane.science.mathematics.logic.coq.club
The following message is a courtesy copy of an article
that has been posted to gmane.science.mathematics.logic.coq.club as well.
Ian Lynagh
<igloo AT earth.li>
writes:
> Reserved Notation "a &&& b" (at level 50).
> Record And (A B:Prop) := {
> foo : Prop -> Prop -> Prop
> where "a &&& b" := (foo a b);
> conj : A -> B -> A &&& B -> Prop
Thank you Ian! That's exactly what I wanted. One more question: where
do I place the "where" clause if the Notation uses identifiers which are
parameters of the Record? For example, rather than write this:
Record Foo (func:Type->Type->Type) :=
pf : func Set Set = Set
I would like to write
Reserved Notation "a ~> b" (at level 30).
pf : Set ~> Set = Set
AUGER Cédric
<Cedric.Auger AT lri.fr>
writes:
> Your example is quite strange for defining the And; I would rather do:
Yes, the example I posted was completely artificial. The real case I
have in mind is very large and I didn't want to make people read through
the whole thing just to answer my question.
- a
- [Coq-Club] [Reserved Notation] and [Record], megacz
- Re: [Coq-Club] [Reserved Notation] and [Record],
Ian Lynagh
- Re: [Coq-Club] [Reserved Notation] and [Record], AUGER Cédric
AUGER Cédric
- [Coq-Club] Re: [Reserved Notation] and [Record], Adam Megacz
Ian Lynagh
