- To: Christian Doczkal <doczkal AT ps.uni-sb.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Warning: Ignoring recursive call
- Date: Mon, 15 Mar 2010 08:56:19 -0400
Christian Doczkal wrote:
I have the following setup (which follows no intuition but is a
simplified version of the original inductive type reproducing the
effect)
Section T.
Variables (X: Type) (x:X) (A : X -> Prop) (f : forall (x:X), A x -> X ->
X).
Inductive AllList X (P : X -> Prop) : list X -> Prop :=
empty : AllList _ P nil
| acons : forall x xs , P x -> AllList _ P xs -> AllList _ P (x::xs).
Inductive R : X -> Prop :=
| intro0 : forall x x' a , R (f x a x') -> R x'
| intro1 : forall xs x', AllList _ (fun x => { a : A x | R (f x a x')} ) xs
-> R x'
| intro2 : R x.
On entering R i get: "Warning: Ignoring recursive call"
1. Question: What does this warning mean and does it have any
consequences on the consistency of the system?
The warning is just about the heuristic attempts to generate a useful induction principle. Nested inductive types (like your [AllList] use here) call for some cleverness to build the right inductive case schemas.
If I remove either intro0 or intro1 (intro2 is just added to not make it
a single constructor inductive proposition) the warning disappears.
2. Question: The above shows that being well-formed (in the sense of no
warnings being issued) is not a property that can be verified in a
rule-by-rule fashion. Can someone explain this?
Since Coq ignores nested inductive types in generating induction principles, it interprets "R minus intro0" as a non-recursive type. Therefore, the "induction principle" is not recursive, so there is no recursive call to ignore. Just removing "intro1" leads to a nesting-free type, for which the most natural induction principle is easily generated.
In case you decide you want a nice induction principle for [R], you might be interested in Section 3.7 of CPDT:
http://adam.chlipala.net/cpdt/
- [Coq-Club] Warning: Ignoring recursive call, Christian Doczkal
- Re: [Coq-Club] Warning: Ignoring recursive call, Adam Chlipala
