- To: Christian Doczkal <doczkal AT ps.uni-sb.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Recursive Notations and LL1 parsing
- Date: Tue, 16 Mar 2010 12:47:43 +0100
Hi,
> Im Experimenting with Notations (for Ensembles)
> Require Export Ensembles Finite_sets.
> Implicit Arguments In [U].
> Implicit Arguments Finite [U].
> Implicit Arguments Included [U].
> Implicit Arguments Add [U].
> Notation "{{ x , .. , y }}" := ( Add .. (Add (Empty_set _) x) .. y) (at
> level 0, x at level 99).
> Notation "{{ x : A | P }}" := (fun x : A => (P : Prop ))(at level 0, x at
> level 99).
> Notation "{{ x | P }}" := (fun x => (P : Prop ))(at level 0, x at level 99).
> Goal forall x y z , Included {{ x , y }} {{ x , y , z }}.
> Toplevel input, characters 112-113:
> Syntax error: '|' or ':' expected after [constr:operconstr level 99] (in
> [constr:operconstr]).
> I understand that due to the LL1 nature of the Notation Parser the
> common initial parts of all the notations need to be at the same level.
> Each of the two notation groups in isolation works as expected but is
> there a way to keep the second group from hiding the recursive notation?
As shown by "Print Grammar constr", the "{{ x , .. , y }}" is in fact
not factorized with the other "{{ }}" notations.
[ "{{"; constr:operconstr LEVEL "99"; "|"; constr:operconstr LEVEL "200";
| "{{"; constr:operconstr LEVEL "99"; ":"; constr:operconstr LEVEL "200";
"|"; constr:operconstr LEVEL "200"; "}}"
| "{{"; LIST1 (constr:operconstr LEVEL "99") SEP [ "," ]; "}}"
You can solve the problem by splitting your recursive notations in two
parts as follows:
Notation "{{ x }}" := (Add (Empty_set _) x) (at level 0, x at level 99).
Notation "{{ z , x , .. , y }}" := ( Add .. (Add (Add (Empty_set _) z) x) ..
y) (at level 0, z at level 99).
This by the way suggests that Coq applies this decomposition
automatically. We'll try.
Hugo Herbelin
- [Coq-Club] Recursive Notations and LL1 parsing, Christian Doczkal
- Re: [Coq-Club] Recursive Notations and LL1 parsing, Hugo Herbelin
Qiang Liu
- Re: [Coq-Club] Recursive Notations and LL1 parsing, Adam Koprowski
Qiang Liu
