coq-club - Re: [Coq-Club] Program and coercions
chronological Thread
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Program and coercions
  • Date: Wed, 17 Mar 2010 12:40:04 -0400
Le 16 mars 10 à 14:24, Matthias Puech a écrit :
Dear Coquists (Coqists?),
I'm trying to use Program to prove the decidability of some predicates,
stated with [sumbool] but implemented in [bool]. Program doesn't like
this, so I define a coercion from {b : bool | if b then A else ~A} to
{A}+{~A}. And the other way around to be sure I'm not mistaken. Still,
Program doesn't seem to see my [sumbool] as a [sig]! Is it a known
issue? Or do I get it totally wrong (the most probable)?
I know, with the coercions I could define the function with type [sig]
and then use it as a [sumbool], but I was thinking it would be nice to
have one canonical representative of the (multiple way to define the)
"decidable" predicates, and coercions to it from the others. Is this
concern futile? Is there another, beautiful way?
Dear Matthias,
The reason this does not work is that Program does not handle coercions
as you seem to expect. [eq_nat_dec] typechecks if you give it the type
[decidable2 (m=n)] as it can find a subset coercion from [bool] to
[{b:bool|...}] but when you try to coerce [bool] to [decidable] it is
unable to infer that there is a subset coercion path from [bool] to [decidable2]
and then a regular coercion from [decidable2] to [decidable]. The two
coercion systems simply do not work together that way and this would
require a substantial change to the existing coercion system. However,
you can force this transitive coercion using casts:
Program Fixpoint eq_nat_dec m n : decidable (m=n) :=
 match m,n with
   | 0, 0 => (true : decidable2 (0=0))
   | S p, S q => if eq_nat_dec p q then left _ else right _
   | x, y => (false : decidable2 (x=y))
 end.
The casts from [bool] to [decidable2] are handled by Program coercions
and the resulting [decidable2] values are coerced to [decidable] using
the declared [sumbool_of_sigbool] coercion. I would suggest sticking
to one representation when programming. If you chose [sumbool] you could
also write:
 match m,n with
   | 0, 0 => left _
   | x, y => right _
 end.
Hope this helps,
-- Matthieu
