coq-club - Re: [Coq-Club] crush tactic
chronological Thread
  • To: Michael Day <mikeday AT yeslogic.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] crush tactic
  • Date: Tue, 23 Mar 2010 09:07:35 -0400
Michael Day wrote:
I do have one question: could the crush tactic be extended to call constructor? In several proofs I've ended up with situations like this:
crush ; constructor.
And I thought that constructor was a relatively "safe" tactic that crush could probably try just to see if it works. Is this not the case?
If you change that to:
    crush; try solve [constructor].
then this would certainly be "safe," with the only potential downside that I can think of being a performance cost. If you don't enforce that the constructor solves the goal, then you can easily replace a true goal with a false goal, since multiple constructors can apply to the same goal.
In each case, have you run [Hint Constructors] for the inductive type in question? I would expect that would lead [crush] to solve these goals as-is.
