- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Program fixpoints with measure
- Date: Sat, 27 Mar 2010 14:08:42 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:subject:message-id:in-reply-to:references :organization:x-mailer:mime-version:content-type :content-transfer-encoding; b=qEwScL6obEY1wVQZgRth1+c6hZMP8CTIv6/abZT3bYb9fB3AXcfxNZo+YVskdTBfpc gPWZ64qFdfMxRw/OcRDy2EIpXZWDfjugqbUPZ9qzHCwCWgOPCyUmbCUmy9y5Qx3swHZJ Sc6hO2NK2lOQMDe7tV3jQrVKL3ia4bMFt7kkY=
- Organization: CNAM
On Sat, 27 Mar 2010 20:54:39 +1100
Michael Day
<mikeday AT yeslogic.com>
wrote:
> Hi,
> Recently I have been using the "measure" function of Program to create
> fixpoints that decrease on some measure of the arguments, which is
> enormously useful for proving termination of functions that are not
> structurally recursive in an obvious way.
> However, reasoning about these fixpoints in later proofs is hard, as
> they expand to a large term based on Fix_measure_F_sub that is difficult
> to simplify during induction proofs.
> Are there any common tips or tricks for working with measure functions
> effectively? In the Program.Wf module there is a lemma called F_unfold
> and some others, can these be used for manipulating terms during proofs?
> Best regards,
> Michael
> Print XML with Prince!
> http://www.princexml.com
Hi,
you can try to use Function instead of Program Fixpoint. The two
feature are not exactly equivalent. In particular, Function will give
you a fixpoint equation for you function (aka a proof that $forall x, f
x = body_of_f$) and an induction principle for f which will (hopefully)
help you to reason about f.
Best regards,
Julien Forest
- [Coq-Club] Program fixpoints with measure, Michael Day
- Re: [Coq-Club] Program fixpoints with measure, Julien Forest
Michael Day
- Re: [Coq-Club] Program fixpoints with measure, Michael Day
Michael Day
