coq-club - Re: [Coq-Club] Which Lablgtk2 works with 8.3?
chronological Thread
  • To: Tom Hutchinson <thomas.hutchinson AT sophia.inria.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Which Lablgtk2 works with 8.3?
  • Date: Sat, 27 Mar 2010 20:39:06 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=rWiRmM60lZmxo7dMigwYd40auR9B576FPDe9J+dvHEw38yToqCACJh5c2VbKVVKTjz YlE8lVL6vEUVRpFeL2Z1ST8TrqP9acZHMFHl0YRpGSOTSMFsceYRmE4JMr+8UFGMYQRg yN4Bb/etDKPwAHjokd0DJ4ITv0xs6Xm4xd498=
On Fri, Mar 26, 2010 at 8:06 AM, Tom Hutchinson
 wrote:
> Was your lablgtk2 installed with an rpm (or manually by source)?
> If it's an rpm, then maybe you need to install lablgtk2-devel. (I don't
> know much about OpenSUSE so it's just a guess)
> I compiled CoqIDE with lablgtk2 2.14.0. Still, the file /ide/utils/okey.ml
> hasn't been changed in years. I would be surprised if it required a really
> recent lablgtk version.
> http://docs.camlcity.org/docs/godipkg/3.10/godi-lablgtk2/lib/ocaml/pkg-lib/lablgtk2/gdk.mli
> It looks like there is a Gdk.Tags.modifier
> This is from 2.12.0 (see bottom:
> http://docs.camlcity.org/docs/godipkg/3.10/godi-lablgtk2)
CoqIDE(8.2pl1 and 8.3) was finally installed on openSUSE 11.2. In case
someone else needs it:
First installed lablgtk2-devel, the latest version from YaST2 is
12.0.1. Then the errors from
/ide/utils/okey.mli were gone. But then there was another linkage
error, about 'cannot find
dlllablgtk2.so', which was also reported at
'http://logical.saclay.inria.fr/coq-puma/messages/619bff6dadbe2454'.
Followed that suggestion,
1. make distclean
2. ./configure -coqrunbyteflags -custom <whatever-options-you-want>
3. make
that linkage error was fixed. Then, more linkage errors:
1) cannot find ncurses --> the dev-ncurses should also be installed
2) could not find gtk-x11-2.0
    this was fixed by sudo ln -s gtk-x11-2.0.so.1 gtk-x11-2.0.so
3) make softlinks at /usr/lib for the following libs too
    gtk-x11-2.0 gdk-x11-2.0 atk-1.0 gio-2.0 pangoft2-1.0
gdk_pixbuf-2.0 gobject-2.0 pangocairo-2.0 cairo pango-1.0 freetype
fontconfig gmodule glib-2.0
This completes the installation.
A dev-version of lablgtk2 provides dlllablgtk2.so
http://rpm.pbone.net/index.php3/stat/4/idpl/11743232/com/lablgtk-2.12dev-13.1.i386.rpm.html
I guess this can fix the problem too, but it works if frama-c is
installed, and has other dependencies.
> Tom
> On Mar 26, 2010, at 12:04 AM, Jianzhou Zhao wrote:
>> Hi,
>> I got the error when compiling 8.3:
>> ./ide/utils/okey.mli line 33
>> Unbound type constructor Gdk.Tags.modifier
>> This seems a problem from Lablgtk2:
>http://caml.inria.fr/pub/ml-archives/ocaml-beginners/2004/01/c57a676198b126994795763abf5ad5b1.en.html
>> I used
>>  Camlp5 version 5.13 (ocaml 3.11.0)
>>  Lablgtk2 with 2.12.0
>>  OpenSUSE 11.2
>> What is the correct Lablgtk2 CoqIDE needs?
>> I remember I had the same problem when I compiled 8.2 last year,
>> and commented CoqIDE compilations.
>> Thanks
>> Jianzhou
Jianzhou
