- To: Muad Dib <muad.dib.space AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Can this universe inconsistency be resolved?
- Date: Fri, 26 Mar 2010 22:36:49 +0100
hi,
you should give the carrier as a parameter to the setoid
Record Setoid (T:Type) := {
rel: relation T;
rel_equiv: equivalence rel
which is more or less how it is done in coq.
(try
Require Export Classes.SetoidClass.
Print Setoid.
do the same for the definition of 'category', see for example matthieu's
development at
http://mattam.org/research/coq/classes.en.html
where he defines a category of categories, afair (or better, a
categorical structure on categories).
btw, you might want to use the built-in setoids of coq instead of
redoing all the work.
greetings
ben
Muad Dib wrote:
> Hi coq-club,
> I am trying to write out some category theory definitions into Coq,
> and I had got quite far before I realized that I was using the
> identity equality rather than setoid! When I try to change it I am
> having seemingly impossible difficultly because of this universe
> inconsistency:
> Record setoid : Type := { carrier : Type }.
> Record Category : Type := { Ob : setoid }.
> Definition category : setoid := Build_setoid Category.
> If we make: Record setoid' : Type := { carrier' : Type }. and define
> category : setoid' instead -- it is allowed. but in that case I could
> not use (small) categories as the objects of a category. So my
> question is how could this be resolved? What I am also wondering about
> is that if we had quotient types in Coq, maybe this would be a lot
> easier.. but I am not sure what sort of theoretical difficulty there
> is with quotients compared to setoids.
> Thanks in advance!
- [Coq-Club] Can this universe inconsistency be resolved?, Muad Dib
- Re: [Coq-Club] Can this universe inconsistency be resolved?, ben
- <Possible follow-ups>
- Re: [Coq-Club] Can this universe inconsistency be resolved?, David Leduc
