- To: Michael Day <mikeday AT yeslogic.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Hints and the crush tactic
- Date: Tue, 30 Mar 2010 10:56:21 -0400
Hi Michael,
Le 30 mars 10 à 07:47, Michael Day a écrit :
Hi Adam,
I'm pretty sure [crush] will solve any goal that [auto] can, because [crush] calls [intuition], which calls [auto]. [eauto] is a different story, which, like Adam Koprowski suggested, I leave out because it can increase proof search time dramatically.
Thanks, that makes sense. Having run into a few situations now where eauto is too eager and grabs the wrong hypothesis, perhaps it is good to have them as separate tactics.
Oh, do you have any suggestion as to how to make crush apply app_eq_nil in hypotheses using hints by any chance? :)
The [auto] resolution tactic does not support hints that change the hypotheses currently.
It keeps an index of the hypotheses that can be applied at the beginning of a search and
updates it only when [intro]ducing new ones, not if the hypotheses change by other means.
This limitation is lifted in the typeclass resolution tactic [typeclasses eauto with ...]
where that index is rebuilt each time the hypotheses change.
Hope this helps,
-- Matthieu
- Re: [Coq-Club] Hints and the crush tactic, (continued)
Michael Day
- Re: [Coq-Club] Hints and the crush tactic, Michael Day
Adam Koprowski
Michael Day
Adam Koprowski
Michael Day
- Re: [Coq-Club] Hints and the crush tactic, Adam Koprowski
- Re: [Coq-Club] Hints and the crush tactic, Adam Chlipala
- Re: [Coq-Club] Hints and the crush tactic, Matthieu Sozeau
Michael Day
Adam Koprowski
Michael Day
Michael Day
