coq-club - Re: [Coq-Club] local definition in proof mode
chronological Thread
  • To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • Cc: andr� hirschowitz <ah AT unice.fr>, Martijn Vermaat <martijn AT vermaat.name>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] local definition in proof mode
  • Date: Tue, 6 Apr 2010 13:53:12 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=E9JZY+9jarFAnMTCpoAKGa9FciLc/M6kGQ9FhBKlb3mplvAyy42733G1LHv7B/4vO0 1jB2FXLex6uuhGDLZTiIMppQ73v7UF2zuTkEnjZAOzwTbdAh+/AIKJ5NTd8um8IerDiq DkwLpeGPeV3XlOD0XScDpdBwcAYt2W9+ZoKBo=
The main difference is that assert do not provide you explicitly with the term you just constructed.
I cannot see how to do this without proving a sublemma and finish its declaration by Defined instead of Qed and then use this sublemma in your developpement with the "pose (H := Mylemma)" feature.
gallais
On 6 April 2010 13:32, Stéphane Lescuyer <stephane.lescuyer AT inria.fr> wrote:
I don't see what is the problem with assert, "assert (H : P)" is
basically "cut P" with the goals generated the other way, so it is
exactly what you asked for in your first message ; in particular, it
does add an hypothesis named H of type P in the second goal.
Note that assert can be used as pose as well : "assert (H := t)" will
act as "pose (H := t); clearbody H".
HTH,
Stéphane
On Tue, Apr 6, 2010 at 1:22 PM, andré hirschowitz <ah AT unice.fr> wrote:
> no, if I experiment correctly.
> assert generates two goals and does not forward to the second one the
> formula produced for the first one.
> Thanks for your answer.
> ah
>> I think you are looking for the following?
>>  assert (myname : mytype).
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
