- To: Eric Jaeger <eric.jaeger AT ssi.gouv.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Tackling arity?
- Date: Wed, 14 Apr 2010 08:21:28 -0400
Eric Jaeger wrote:
I'm currently trying to revisit some Coq code to improve automation
(digging further in Ltac) and notations. I've for example several
definitions to relate a predicate and a boolean function deciding this
predicate:
Definition implements1(T:Type)(P:T->Type)(f:T->bool):=
((forall (t:T), f t=true->P t) * (forall (t:T), f t=false->P
t->False))%type.
Definition implements2(T1 T2:Type)(P:T1->T2->Type)(f:T1->T2->bool):=
((forall (t1:T1)(t2:T2), f t1 t2=true->P t1 t2) *
(forall (t1:T1)(t2:T2), f t1 t2=false->P t1 t2->False))%type.
That is, one definition per arity.
1/ Is there an elegant way to merge these definitions (possibly
internally relying on currification, but noting that I do not want to
use A*B->C instead of A->B->C at top level) ?
This might fit the bill, for a slight simplification where I change your "predicates" to return [Prop] instead of [Type]:
Fixpoint multi (dom : Type) (n : nat) (ran : Type) : Type :=
match n with
| O => ran
| S n' => dom -> multi dom n' ran
end.
Fixpoint agree (dom : Type) (n : nat) : multi dom n Prop -> multi dom n bool -> Prop :=
match n with
| O => fun P b => IF P then b = true else b = false
| S n' => fun Pf Bf => forall x : dom, agree dom n' (Pf x) (Bf x)
end.
Eval compute in agree nat 0.
Eval compute in agree nat 1.
Eval compute in agree nat 2.
- [Coq-Club] Tackling arity?, Eric Jaeger
- Re: [Coq-Club] Tackling arity?, Adam Chlipala
- Re: [Coq-Club] Tackling arity?, Stéphane Lescuyer
